Building New Computer but I need help
As stated in the title of this thread, I am currently planning to build a gaming computer. There is one problem; I need to check if each part is compatible with each other.
If there is a way to check (instead of googling each part and seeing if each one is compatible) please do tell. Also, this is my first time building a computer from scratch.
I prefer to buy my parts manually instead of by mail but my local computer parts store ( http://www.microcenter.com/index.html ) has a weird shopping cart so the parts are listed here:
Processor: http://www.microcenter.com/single_product_results.phtml?product_id=0388577
Motherboard: http://www.microcenter.com/single_product_results.phtml?product_id=0387554
HDD: http://www.microcenter.com/single_product_results.phtml?product_id=0298929
SSD: http://www.microcenter.com/single_product_results.phtml?product_id=0364780
RAM: http://www.microcenter.com/single_product_results.phtml?product_id=0387518
Graphics Card: http://www.microcenter.com/single_product_results.phtml?product_id=0386227
PSU: http://www.microcenter.com/single_product_results.phtml?product_id=0380192
Case: http://www.microcenter.com/single_product_results.phtml?product_id=0355148
DVD Drive: http://www.microcenter.com/single_product_results.phtml?product_id=0392825
Processor Heatsink: http://www.microcenter.com/single_product_results.phtml?product_id=0333155
Total: $1,089.45
I obviously know that my processor, graphics card, and mother board are compatible but I'm not so sure if they are compatible with the rest of the parts. Also, if you have any suggestions on making my computer better, or just know that one of these parts are not compatible or not good, say a replacement from the website that is above.
7 answers Last reply
More about building computer help
  1. On a scale of 1-10
    CPU-9
    Motherboard-8
    Hdd-5
    ssd-8
    ram-8
    GPU-7
    PSU-8
    Case-9
    DVD drive-doesnt matter
    Heatsink-5 do this http://www.amazon.com/Noctua-Heatpipe-Bearing-Cooler-NH-D14/dp/B002VKVZ1A/ref=sr_1_11?ie=UTF8&qid=1342134232&sr=8-11&keywords=cpu+cooler
    I would chnge the hdd,cpu cooler and gpu I would get a 1tb hdd, If you can get a 7850 then do,get the heatsink I put if it i out of yor budget change the 1tb and call it good.
  2. Like I said in the thread starter, please look up suggestions in the website above ( http://www.microcenter.com/index.html ) I do not trust a truck with a expensive build D:
    Also, GTX 480 > HD 7850 Price and performance wise.
    This good? http://www.microcenter.com/single_product_results.phtml?product_id=0393267
  3. What does dollar per dollar mean? (New to this) and uneducated statement:
    But the 480 is cheaper (at microcenter) and performs better
    Also, is there a good CPU cooler that you can find on the website?
    Also, also, does the power supply fit in my Inspiron 530? (so I don't have to buy extra things I don't need)
  4. Bang for buck
    No the gtx 480 performs similar but it cosmes more power it is HOT and it is 2 generatons ago.
    CPU cooler get a cooler master hyper 212 evo
    the psu should fit if you had one in there before put the new one in it's place.
    It has a stock psu in it currently
  6. They are all the same size. :P
Homebuilt Computer Compatibility Systems
