First Build Advice
Hey I just want to say thanks in advance. I have recently been looking to upgrade my computer because I'm playing games with higher requirements. I have most of the parts chosen I just want to make sure I didn't over look some detail.
Parts I Have Chosen:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=18980065
Approximate Purchase Date: sometime around end of July early August
Budget Range: Want to stay to as close to 1000 as possible
System Usage from Most to Least Important: Gaming, surfing the internet, watching movies
Preferred Website for Parts: Newegg.com
Parts Preferences: Intel
Overclocking: Probably
SLI or Crossfire: Maybe in the future
Going to get Monitor preferably 1920x1080 and am thinking of eventually going to dual monitor. I will also need to get a operating system which will be windows 7, just need to choose which one. Thanks a ton I want to make sure this build goes good. If there's anything I'm missing please let me know. Thanks again.
6 answers Last reply
More about first build advice
  1. Looks good man, but the power supply you picked is not in production anymore and it's also way more wattage than you'll need: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
    I also recommend this GTX 570 instead of the 560 ti that you picked; they are both practically the same price:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593
    or if you want a different cooler and cheaper card:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127682
  2. Hey thanks man. I dont know if this ones any good but its the one that's that supposed to be on the wish list
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127565
    Sorry about that.
  3. A 7850 would be better
  4. Yeah 7850 or 7870 would be a better.
    7870:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127662
    7850:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127663
    but other than that it seems a pretty good build apart from the power supply which the guy already mentioned :)
  5. Thanks a bunch I'll probably order the parts when I get back from vacation
  6. If you didn't get that vacation you could Have gotten top of the line stuff.... LOL
New Build Systems Product
