620W Power Supply Question
Hello,
Can a 620W Power Supply (GIGABYTE PSU Suberb E620, 620W, 80 , SLI, Active PFC) run a CPU with a Intel i5 3550 Processor, GIGABYTE MB GA-Z77X-D3H 1.0 Motheboard, Seagate 500GB Sata3 16MB 7200rpm/m HDD, Kingston 8GB DDR3 1600mhz Memory, ASUS VGA GTX 650 Ti Graphic Card, Thermaltake V3 Black Edition with one 120mm fan? (Other components: Wireless USB mini card, ACER 22" FULL HD monitor, keybord, joysticks etc)
Is 620W enough? Thanks for your help.
5 answers Last reply
More about 620w power supply question
  1. Zlayatoure said:
    Hello,
    Hi - Yes, 620w is more than enough. However, the PSU you mention might not be reliable.
    I read somewhere that this PSU line is far from superb.
    If you already own it, then go ahead. If not, then consider another brand, i.e. Seasonic, Corsair, Antec, XFX.
    Tom
    http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=12&ved=0CDgQFjABOAo&url=http%3A%2F%2Fwww.hardwaresecrets.com%2Farticle%2FGigabyte-Superb-550P-Power-Supply-Review%2F968&ei=FsmvULzwG6Wz0QGlsYCQBw&usg=AFQjCNGJRBwHAn2lho0KScUvS9PYN18eaQ&sig2=Xp5zLx5nCUiC_8ZBe7KUCg&cad=rjt
    just go to the conclusions page
  2. I don't own it. I want to buy a PC with the configuration I mentioned. I was just wondering if 620W is enough. What's the mimimum W for this configuration, btw? And which PSU would you recommend? (ofc, it shouldn't be too expensive)
    Thanks.
    Thanks.
    Hi again - A quality 400w PSU would suffice, emphasis on quality. 500w would give you breathing room and
    the ability to upgrade your GPU in the future. As far as what I'd recommend, I need to know your budget.
    Good news (if you are in the US) is there some really good deals being offered, limited time of course.
    Tom
    Tom
    Nope. I'm from Europe. I was considering to buy a In Win GreenMe 650W PSU. It's about 50€, and it seems to be a really good PSU. Thanks again.
    That is a good unit - well reviewed by Hardware Secrets -go for it
    Tom
Power Supplies Components
