Approximate Purchase Date: e.g.: before 28 August 2012
Budget Range: 2000$
System Usage from Most to Least Important: gaming (playing on max)
Are you buying a monitor: Yes
Parts to Upgrade: None
Do you need to buy OS: No
Preferred Website(s) for Parts:newegg.com
Parts Preferences: Intel build
Overclocking: Yes
SLI or Crossfire: Yes (will buy a second GPU in the future)
here are the parts:
Case HAF X $179.99
http://www.newegg.com/Product/Prod [...] 6811119225
Mobo Asus Maximus Formula V $289.99
http://www.newegg.com/Product/Prod [...] 6813131854
CPU Intel Core i7-3770K Ivy Bridge 3.5GHz $339.99
http://www.newegg.com/Product/Prod [...] 6819116501
RAM G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
SeaSonic X Series X-850 (SS-850KM Active PFC F3) 850W ATX12V v2.3 / EPS 12V v2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply $199.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151102
SSD Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Prod [...] 6820148442
GPU ? whichgtx 680 (will do sli in future)
after market cooler for OC ?
Hard drive for storage ?
Gaming keyboard & mouse ?
Gaming monitor?
any suggestions?
Thanks for helping.
Budget Range: 2000$
Overclocking: Yes
here are the parts:
Case HAF X $179.99
Gaming monitor?
any suggestions?
Thanks for helping.
