Archived from groups: microsoft.public.windowsxp.customize (More info?)
I received a zip file from a software manufacture. It has a total of 15
files in it. When you open or extract the files using the WindowsXP
Built-in Zip Program, it only shows 14 files in the folder window and will
unzip only 14 files.
When using a third-party zip program such as WinZip or PowerArchiver both
shows all 15 files in the folder window and will unzip all 15 files.
The file name is "M5 Pages, Components and Help.msi" which is unusual in
that it has a comma in it.
Why will the WindowsXP Built-in Zip Program not see this file? Is there any
way to correct this problem other than to buy a third-party zip program?
In news:uhfwv7TMFHA.3960@TK2MSFTNGP12.phx.gbl,
jw <jw@hotmail.com> had this to say:
My reply is at the bottom of your sent message:
> 15 files in it. When you open or extract the files using the
> WindowsXP Built-in Zip Program, it only shows 14 files in the folder
> window and will unzip only 14 files.
> both shows all 15 files in the folder window and will unzip all 15
> files.
> in that it has a comma in it.
> there any way to correct this problem other than to buy a third-party
> zip program?
> Thanks
> JW
