Solved
A10 5800k heat problems, other questions
My a10 seems to be overheating and throttling itself at stock speeds. Is this abnormal?
HWmonitor reads a max of 79C under load, and a min of 45C, with basic web browsing at mid 50's
This seems crazy high. I had a spare generic copper base/heatpipe cooler, threw it in and got same temps with silver compound paste.
My second question pertains to bios settings. Is there anything I need to change in the BIOS other than memory profiles out of the box for a trinity set up? My MSI board has all this graphical crap and is an extreme pain to navigate. I'm worried that I missed a selection for the radeon "on board" graphics or an option that assigns memory to the video.
Thirdly, should my cores be reading 4Ghz across the board at idle? I thought it down-clocked if not in demand?
I'm kind of disappointed that this setup is choking on basic games, and wanted to make sure I'm not missing something.
I appreciate your time and any help would be appreciated!
Edit: I wanted to add that I just ran 3dmark11, and the scores seem very low end comparatively.
P1597
Graphics - 1460
Phys - 3953
Combined - 1348
With a peak temp of 82C during the test (YOW!)
I think something is wrong.
6 answers Last reply Best Answer
More about 5800k heat problems questions
    Thats kind of hot, are you using the stock cooler or aftermarket cooler?
    Right now Im using a Deep Cool cpu cooler with copper heatpipes. It's not the best but I figured it would be better than the stock one.
  3. I would make sure the heatsink is on right and re-apply thermal paste, you might have used to much or to little.
  4. Here's what i've discovered.
    I originally used an intel overclock profile in the bios to get my ram at 1866mhz. This was a bad idea. I reset the defaults, and manually set the frequency through another option. The memory overclock profile was causing my turbo core to stick on max clock all the time.
    Ran a benchmark and hit 82C again, but lower idle temps.
    now im thinking I need a competent cooler, so i bought the hyper 212 on amazon prime. In the meantime, I turned turbo core max down to 3.8 Ghz, and my idle temp is sitting at 32C-34C.
    Think this is right?
  5. Best answer
    Yes that seems fine for now. See if the new cooler does anything. Also when you apply thermal paste you only need a small amount, a small dod 5-5.5 mm's in size (about the size of a pea) will be fine.
  6. Best answer selected by helfrichi.
CPUs
