Hello everyone, been putting this together for a while...it is going to be my first build. However, I've been doing a self check on things so far and thought I should have some others take a look to make sure my things are in order.
Also I'm still in need of a power supply, I was thinking something around 700W, but I don't know if that's far over what I'd need or not. I figured it would be fairly high. At the moment I'm sticking to Newegg on my parts...just got a wishlist put together. It's purpose is to play games, and some CAD.
I'm open to all comments and rants. Thanks in advance!
Here is what I got lined up right now:
I5-2500k (http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072)
Asus Mobo (http://www.newegg.com/Product/Product.aspx?Item=N82E16813131826)
7850 Radeon (http://www.newegg.com/Product/Product.aspx?Item=N82E16814121623)
8GB Ram (http://www.newegg.com/Product/Product.aspx?Item=N82E16820220558)
120G SSD (http://www.newegg.com/Product/Product.aspx?Item=N82E16820227726)
1TB HD (http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840)
912 HAF case (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233)
H60 Hydro (http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015)
Again, all opinions and comments welcome!
