Hi Everyone,
This is my first post here and this is my first build. I have just recently started looking into building a gaming desktop and so I'd like to apologize ahead of time for any redundant questions I may ask and my inexperience with building a computer. Anyways this build is unfinished mainly because I'm unsure of what I should be looking for when buying the parts and so I'd like your opinion of what would I should buy. Also the build started/is based around 2 GTX 560s (non TI) that my dad had bought and (as a side goal) hopefully create a 3 monitor setup. Opinions, recommendations, and constructive criticisms are appreciated.
Approximate Purchase Date: e.g.: Next week (or this week)
Budget Range: $500 - $700 (excluding everything already bought)
System Usage from Most to Least Important: Gaming (primary purpose), watching movies, video editing, surfing the web.
Are you buying a monitor: Yes / No
Parts: (the ones I've found so far...)
- CPU: Core i5 3570K 3.4GHz LGA 1155 Processor
http://www.microcenter.com/single_product_results.phtml?product_id=0388577
- GPU: GTX 560 (non TI) SLI 1gb (already bought)
- Motherboard: ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
- PSU: ? (700W +)
- Case: ?
- CPU Cooler: ?
- HD: Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
- SLI Bridge: Nvidia 120mm long SLI flexible bridge cable interconnect connector
http://www.amazon.com/Nvidia-flexible-bridge-interconnect-connector/dp/B0025VT6LQ
- RAM: Kingston HyperX Genesis DDR3 2133MHz (already bought) 4x4GB
- DVD burner/drive: ?
Is there anything else missing?
Do you need to buy OS: Yes / No
Preferred Website(s) for Parts: newegg.com, microcenter.com, amazon.com
Parts Preferences: Uhmmm.... not really...
Overclocking: Yes / No / Maybe (later on possibly)
SLI or Crossfire: Yes / No / Maybe
Your Monitor Resolution: whats recommended? Where can i get a decent monitor that's not too expensive? I would like to build a 3 monitor setup, but it may get a bit pricey so we'll see.
Additional Comments: Like I had said earlier, this whole build started when I got 2 GTX 560s from my dad. My whole build will be based on an SLI of the GPUs. I would like to eventually be able to have a 3 monitor setup but that's only a side objective. I'd like to build a decent computer first.
Why Are You Upgrading: Not really upgrading but I'm really interested in learning more about computers and such so I wanted to try building a computer at least once.
Thanks!
- Brandon
- PSU: ? (700W +)
- Case: ?
- CPU Cooler: ?
Thanks!
- Brandon
