Your PSU runs (normally) in a semi-fanless mode. The fan does the little movement at first simply to let you know it (the PSU) is on. When heat builds up, or your power draw on the PSU draws enough heat, the fan will come on only as long as it needs to in order to cool the PSU components down. It is not something to be concerned about, in fact it is a feature found only in better power supplies
