Hello. This is my first post, though I come here all the time to look up advice from you guys.
Okay. So I was just surfing the internet when my screen went black. The PC looked like it was on, but nothing was happening. So I did a hard reset. Well, now I can't power on my PC at all with everything hooked in. If I unplug my PC, then plug it in, the fans twitch a little bit, but it fails to turn on. There is still a little orange light from the motherboard, like it is receiving power.
When I unplug my graphics card, the PC will post, and seems to boot, but I only have this graphics card, so I can't actually see the screen and if it is running properly or not. From the outside, the PC seems to be running fine.
Because it will post without the GPU, I am thinking it is either the PSU or the GPU at fault.
Here are my sepcs.
I have a Rosewill 80plus Bronze 650 watt PSU
AMD Saphire 6950 GPU
AMD 6100 3.3GHZ CPU
16gigs of GSkill Sniper Sereies RAM
ASRock Extreme 4 AM3+ Motherboard
If you need more info, just ask. Thank you so much for your help.
Here are my sepcs.
AMD 6100 3.3GHZ CPU
