Closed Solved
CM Stryker Water Cooling
I am planning on water cooling my next build, I will be using the Cooler Master Storm Stryker (White). I'm still unsure on the color I'm going to put inside for my dye/tubes. If you guys could give some suggestions that would be awesome.
Quick note: My mobo will be black.
4 answers Last reply Best Answer
More about stryker water cooling
  1. you could do a black and white build using white coolant
  2. Best answer
    I'd put this in the W/c section as well Hilo, but no dyes, just use coloured tubing
    I'm thinking blue for some reason, it'll look nice against the black and white I reckon
    Moto
  3. Sorry moto, I wasn't sure where to put it because of it dealing mostly with the case, will do though. I'm thinking blue would look good too. I love this case.
  4. Best answer selected by Hilo1222.
Power Supplies Water Cooling Build Cooler Master Components
