Hello,
My 5-year-old, homebuilt PC was working fine until yesterday morning. I press the power: computer turns on, fans all working, but no POST beeps and no display. After 30 secs to 1 minute, it shuts off.
Here's what I've done: I took the mobo and PSU out of the case. I disconnected and removed everything from the mobo. I then connected only the following to the mobo: the CPU and heatsink/fan, one stick of RAM, the graphics card, and the tiny case speaker (to hear the POST beeps). I connected the PSU to the mobo and graphics card. I attached a monitor to the graphics card. I shorted the power pins with a screwdriver to turn on the PC.
Here's what happened: the PC powered up and all fans came on (CPU fan, graphics card fan, PSU fan). I heard no POST beeps and no display came up on the monitor. After about 1 minute, the PC shut itself off.
After this, I did the same thing with all RAM and/or the graphic card removed as well. I never heard any POST beeps in any of these tests, but interestingly I found that with the graphics card removed, the PC did not shut itself off.
I also tried resetting the CMOS with no apparent effect.
Unfortunately I don't have any compatible computer parts lying around that I could swap in or out to diagnose the problem further.
Any idea what's wrong or what I should do next? Thanks for any help provided.
Here are my specs:
MSI P6N SLI mobo
Intel core 2 duo CPU
Mushkin RAM
OCZ PSU 700 watts
EVGA Nvidia 8800 GTS vid card
Here are my specs:
MSI P6N SLI mobo
Mushkin RAM
OCZ PSU 700 watts
