Best watercooling case that doesn't look to nerdy?
  • Power Supplies
  • Water Cooling
  • Cases
  • Components
Last response: in Components
November 25, 2012 1:05:22 AM
Like the title says I want a case where I can water cool 2x 660ti and a 3770k that doesn't look too geeky/nerdy because I have people over at my house often. I use an ATX motherboard and I am going to use a peltier on my CPU. Ask any questions if you need to. Thanks for the help!
More about : watercooling case nerdy
November 25, 2012 1:54:53 AM
What do you define as nerdy?
m
l
November 25, 2012 2:23:17 AM
Something like the HAF X with leds, lots of mesh and the whole "tough" "gamer" type look.
m
l
November 25, 2012 2:37:37 AM
I just found the perfect case. The fractal arc midi looks very conservative and has spacing in the front for a thick 240 rad and can fit a 240 rad in the top.
m
l
a b ) Power supply
November 25, 2012 2:48:02 AM
Maybe the Corsair Obsidian 650D or 800D you could do a custom water cooled Pc with the 800D That case is great for water cooling.
If that's too fancy, maybe the Switch 810 from NXZT.
m
l
November 25, 2012 3:41:41 AM
Many of the corsair or fractal design cases are not "nerdy", most other brands you find will be a gamer type system. The switch is a good in between case, it is both a gamer case, but it is also conservative. It's all about personal preference at this point. (You would hate my case, I am getting a CM Stryker)
Good luck on your decision.
m
l
May 22, 2013 5:53:37 PM
Fractal design define r4... nuff said
m
l
