My Computer was running fine with a 6770, but i returned it and am looking at getting an upgrade.
My concern with a 560, 560 ti, 6850 or 6870 is that they draw more power. I do have a 600 watt PSU, but it is rumored to not be very good. However, Cooler-Master told me that my PSU would be compatible with all four of those cards, and if it is not, they will replace it with a new one. They claimed that it can deliver its rated voltages.
Here it is:
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4434993&CatId=1483
I am pretty sure the 7770 uses less power than the 6770, while still performing better. is this true?
Here are the cards i had in mind, can somebody tell me if it will work?
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1241686&CatId=7005 (Pre-OCed)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1368436&CatId=7005 (REG)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=555335&Sku=E145-1564 (SC)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1781498&CatId=3669 (OC TI)
The first one looked the best to me only because of Shogun 2.
This PSU has to last ~3-4 years, preferably 5 if possible, so capacitor aging must be factored in. The warranty included with the PSU is two years.
Last note, the 7770 is supposed to use less power, but it requires the highest PSU voltage (600 watts)? is that a mistake?
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2060885&CatId=7387
Thanks
Here it is:
Thanks
APPROXIMATE PURCHASE DATE: This week BUDGET RANGE: $100-150 CAD After Rebates
USAGE FROM MOST TO LEAST IMPORTANT: Gaming (Battlefield Heroes, DiRT3, Skyrim, Shogun II, some MMORPG's), Power computing, Youtube, Video calls, Multitasking (on skype with three chrome windows open while playing a game)
CURRENT GPU AND POWER SUPPLY: Gigabyte Radeon HD 6770, Corsair 600 Watt PSU
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=934790&CatId=28
OTHER RELEVANT SYSTEM SPECS: Corsair Vengeance RAM (2 X 4GB), Intel i5-2500k, Asus P8Z68-V LX
PREFERRED WEBSITE(S) FOR PARTS: Preferably Tiger Direct, Maybe Newegg if the price is over $10-15 better.
COUNTRY OF ORIGIN: Canada
PARTS PREFERENCES: No Preference, Something with good tech support and a decent warranty, especially if OC'ed
OVERCLOCKING: Maybe, only if the card is factory overclocked
SLI OR CROSSFIRE: Probably not.
MONITOR RESOLUTION: Currently a 19 inch 1024x768, Will upgrade to a 20-24 inch 1920x1080 monitor soon (In about 1-2 months)
ADDITIONAL COMMENTS: Must be able to run with current PSU, must provide decent performance, and basically everything i listed above. The cheaper the better IMO, also note that i wont be running games with 8XAA or stuff like that, probably just high detail.
