Hey there, I've given it my best shot and now I'm turning to here for my first time for help.
Its a new build with some recycled materials being the RAM, harddrive (with a clean install), 800Watt PSU, and video card.
Current status of computer: turns on half a second, then turns off a few times. It has not powered on since.
Important note: It worked last night perfectly, it ran a high end game just fine. It booted up this morning, but when I tried to fix an audio jack on the front of the case it stopped working (aka, I turned it off, opened the front panel and it never powered on the same after). The parts DO work together when everything is working.
So my main concerns are that the PSU has stopped working or the power button on the front of the case has stopped working, OR the motherboard is toast(?)
What I've Done:
1. checked ALL power supply attachments. **The main power supply to the motherboard is missing what looks like a grounding pin** Looking at the plug I stick into the motherboard they all have copper bits except for that one slot.
2. I've changed power cords on the back.
3. I followed the stickied troubleshooting guide to the point where they have a multimeter. Everything is in order.
Quick edit: So if I flipped the switch on the power supply off for a few seconds, and then turn it back on and then power the front. It'll again turn on for a few brief seconds. Don't know if that means anything.
What I've Done:
