Platinum.
http://en.wikipedia.org/wiki/80Plus
As you can see, the platinum is 2% to 3% more efficient. If you think about it, if your computer is drawing 650 watts, that's an extra 13 watts being wasted, producing nothing but heat. It may not be cost effective to get the platinum supply, but it will run cooler and the fan will run slower.
