Approximate Purchase Date: Couple of weeks.
See im trying to figure out how to make my pc near silent, as at my current setup my cpu cooler + gpu coolers make the most noise, thus pretty much voiding my insanely silent fans.
I will basically be building a new system by replacing what is currently in my 800d corsair case.
My setup will be the following:
Motherboard: MSI Big Bang II
http://www.msi.com/product/mb/Big-Bang-XPower-II.html
Cpu: Intel 3930k
http://ark.intel.com/products/63697/
RAM:
F3-17000CL9Q-16GBZH
http://www.gskill.com/products.php?index=438
SSD:
Not sure yet thinking of either the M4 crucial or 830 samsung.
GPU:
Will be using my current 560ti gigabyte soc till the 700 nvidia series get released.
PSU:
I like the technology of corsairs ax1200i where the fan is shut down till over 40% load is used.
http://www.tomshardware.com/news/AX1200i-Digital-ATX-80_PLUS_Platinum-psu,15931.html
This:
http://www.amazon.co.uk/Seasonic-P-1000-Platinum-Series-Supply/dp/B00608FKN8/ref=sr_1_7?ie=UTF8&qid=1339265819&sr=8-7
Has the same technology, but was hoping to find something a bit more Wattage.
I am searching for something with similar technology and the sweet spot or perfect spot seems to be a 1500w one that turns of its fan untill over 40% should keep the fan turned off even at full load on my setup.
But i can not find the right psu yet, i can seem to find psu with that specific technology much.
The Cooling:
This is the tricky part for me, i would like to water cool both my Cpu and future GPU, but ive never done water cooling before, so this worries me a bit.
Now as i said im looking for the quietest setup where i turn my pc and finally for once not hear the sound of a plane taking off, but instead a low noise hum or whisper lvl noise is ok.
The Radiator I am thinking of is SR-1 360:
http://www.hwlabs.com/index.php?option=com_content&view=article&id=9&Itemid=6
Because it works great with low rpm fans.
Theses are my fans Cougar CF-V12H:
http://www.cougar-world.de/en/products/479/vortex-hdb.html
They are pretty silent fans keeps my current setup cool.
Cpu block:
EK Supreme HF Nickel Plated Copper
Im still struggling to find the right pump, because i cant seem to find the right one. I live in Latvia currently. But I am more then happy to get stuff from Amazon uk, or Amazon DE, or localy by using Salidzini.lv, i dont really mind where my stuff come from as long as they can send it to me .
Anyone have any ideas or tips / advice on how i should continue ?
I thought of possibly buying one of those all in one kit as im not sure how to make a full water cooling setup, because im not sure how a full water cooling setup should contain.
Anyways anyone have any ideas or tip for my plan ? And ideas or thoughts on the perfect PSU that fits the bill of what im looking for ?
Cpu: Intel 3930k
RAM:
F3-17000CL9Q-16GBZH
SSD:
GPU:
PSU:
This:
The Cooling:
Cpu block:
