Front Panel LED Fan starts for 1 second then stops
Last response: in Components
November 26, 2012 9:45:39 AM
I have a blue LED fan that just randomly started not coming on all the way. The LED light comes on and when I start up the computer it turns for a second then turns off. I was messing with some overclocking and Prime95 earlier but I wasn't paying attention if that did anything. Last time I checked if it was working was a week ago when I cleaned out my case. I just happen to look down today and notice the shadow that the fan gives off from the LED light stopped spinning.
November 26, 2012 10:03:03 AM
Is the fan plugged into the motherboard or the PSU?
m
l
November 26, 2012 10:04:41 AM
its connected to the PSU via 4-pin Molex
m
l
November 26, 2012 10:10:25 AM
Hmm... very strange. Can you give us the full specs of your PC? Especially the PSU. It could be starved for power. Have you noticed any instability with the system?
m
l
November 26, 2012 10:33:25 AM
CPU: AMD Phenom II 965 BE
GPU: HiS IceQ 7850 Turbo
MoBo: ASRock 880GM-LE
PSU: Thermaltake 600W
HDD: 500GB
RAM: 2x 4GB Crucial Sticks
I have 3 case fans and Enermax T40 CPU cooler. The other 2 case fans are working, seems to just be the one front panel fan.
m
l
November 26, 2012 10:58:04 AM
If your system is running fine and stable, then I would say that your fan is simply breaking. Can you try plugging the fan into the motherboard?
m
l
