Ok so i just built my first build a few days ago but im lacking a Keyboard and mouse b/c of delayed shipping they wont be here until tomorrow, im also lacking a HDD and windows that im still getting the $ for. Everything else seems to be working fine except the Graphics card (MSI Radeon HD 7770) I Plugged in all the right power connectors and installed it in the PCIE 3.0 16 Slot and hooked it up to my monitor with HDMI into the GPU. Power up the system and all the fans and lights are going great but my Card outputs no signal and the fans on it sit still... so i turn off the system and plug the HDMI into the MOBO and i get the uefi bios... it detects my 8GB of ram and my CPU but says nothing about my GPU (Keep in mind i have no K.B./M.) so thats all i can see. Also another question i had was i built my system and everything but forgot to install standoffs. Everything seems to work fine like loading up the bios and fans/lights/power&reset buttons but should i de-assemble my system and add standoffs or is there really no point.
Incase you need them, my specs :
1 x ($214.99) Intel Core i5-3570 Ivy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637i53570 $214.99
1 x ($139.99) MSI R7770-2PMD1GD5/OC Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card $139.99
1 x ($94.99) ASRock Z77 Pro3 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard $94.99
1 x ($89.99) SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply $89.99
1 x ($79.99) NZXT LEXA S LEXS - 001BK Black Steel ATX Mid Tower Computer Case $79.99
1 x ($59.99) AMD Gift - Dirt SHOWDOWN Gift Coupon $59.99
1 x ($46.99) G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL $46.99
1 x ($11.99) Rosewill RNX-N150PCe (RNWD-11011) IEEE 802.11b/g/n PCIe 2.0 Wireless Adapter Up to 150Mbps Wireless Data Rates WPA/WPA2 (AES, 64,128,152-WEP with shared-key authentication) WPS (WiFi Protected Setup) $11.99
1 x ($-18.00) DISCOUNT FOR PROMOTION CODE$-18.00
1 x ($-59.99) DISCOUNT FOR AUTOADD #49868$-59.99
Subtotal: $660.93
Tax: $0.00
Shipping and Handling: $19.65
Total Amount: $680.58
Subtotal: $660.93
Tax: $0.00
