Is This Power Supply Any Good?
I want to buy this case, but i'm worried if it blows will it take my system with it?
http://www.novatech.co.uk/products/components/powersupplies/nov-psg500.html
Is it safe to use?
Thanks, Adamyjake
13 answers Last reply
More about power supply good
  1. its only got a 2 year warranty
    spend a little more on a well known brand and look for a 5 year warranty
  2. Agreed, PSu is the baseline of a good system.
    Look at the Antec NEO ECO 520w. Cheap but very reliable.
    hey, thanks but i was'nt looking at the warranty, because thats not covered for my other parts of my system only the psu.
    okay thanks, does UVP/OVP/OPP/SCP/OCP/OTP mean its protected? UnderVoltage Protection?? does that portect it?
    yes i know that
    but any decent psu maker has the confidence in their product to give a 5 year warranty
    so therefore only a 2 year warranty implies the psu is made from inferior components
  6. mcnumpty23 said:
    yes i know that
    oh, i see cool. thanks also what do that mean?
    UVP/OVP/OPP/SCP/OCP/OTP ??
  7. SCP - Short circuit protection
    OPP - Overpower (overload) protection
    OCP - Overcurrent protection
    OTP - Overtemperature protection
    OVP - Overvoltage protection
    UVP - Undervoltage protection
    UPS - Uninterruptable Power Supply
    PSU - Power Supply Unit
    SMPSU - Switch-Mode Power Supply Unit
    so this means, if it blows it wont kill any thing else?
  9. in theory--yes
    Yes - if in fact the unit really does have all those protections. The same low end makers
    that lie about the wattage output will also lie about protections.
    However, my gut feel is you're OK til you upgrade.
    Tom
  11. okay thanks, i might go for an xcase psu instead.
    Seriously? How did you get to that conclusion?
    Geeesh - thot he was looking to upgrade!
Power Supplies Cases Components
