Solved
Gtx 670 90-100C load temps!
a b U Graphics card
May 22, 2012 10:05:50 PM
Is this normal?
At idle my gtx 670 is at 37C, at load it slowly ups in temperature.
After it hits over 100C the fan boosts to 100% and knocks off a few degree's :ouch:
Best solution
a b U Graphics card
May 22, 2012 10:14:36 PM
im pretty sure you might have a defective part. might want to check with your manufacturer's site. normal temps are around 60-75 degrees
May 22, 2012 10:14:49 PM
What program did you use for temps?
m
l
a b U Graphics card
May 22, 2012 10:15:56 PM
EVGA precision x
m
l
a c 203 U Graphics card
May 22, 2012 10:37:23 PM
contact evga if it the superclock card they had a bunch that went out the door without being qa tested,
m
l
a b U Graphics card
May 22, 2012 11:07:58 PM
it is the regular standard one, there shouldn't be a problem with it -_-
m
l
a b U Graphics card
May 25, 2012 1:10:57 AM
Best answer selected by maxh22.
m
l
