Solved
Will all the part i have pick work together, and any advice on changes
I have posted a few times before about building my system, i finally have the money together, and wanted final critique before i go ahead
I will be adding an SSD and another 7859 at a later date,
1 x 16011444 - Cooler Master CM Storm Enforcer SGC-1000-KWN1 Case - Mid ATX Tower - USB 3.0 - Black - Steel - 9x Drive Bays - SSD Ready - No Power Supply [$95.00]
1 x 19010246 - Intel Core i5 3570K Unlocked Quad Core 3rd Gen Processor - Socket LGA1155 - 3.4GHz (Turbo Boost @ 3.8GHz) - Smart Cache 6MB - Intel HD Graphics 4000 - Ivy Bridge - 22nm - TDP 77W - Fan - Retail Box (BX80637I53570K) [$245.00]
1 x 28023710 - ASRock Z77 Extreme4 Motherboard - Intel Z77 Chipset - Socket 1155 - 4x 1.5V DDR3 DIMM 2800+ (OC) - 2x PCIe x16 3.0, 2x PCIe x1, 2x PCI Slots - AMD CrossFireX/NVIDIA SLI Ready - 1x HDMI, 1x VGA, 1x DVI Outputs - 4x SATA3, 4x SATA2 - RAID - Up to 8x USB 2.0 & Up to 6x USB 3.0 - Gigabit LAN - 7.1HD Audio - ATX [$149.95]
1 x 37140815 - Corsair Vengeance 8GB(2x 4GB) Dual Channel DDR3 Memory Kit - DIMM 240-pin - DDR3 1600MHz / PC3-12800 - Latency 9-9-9-24 ( CMZ8GX3M2A1600C9) [$65.00]
1 x 42060860 - Sapphire AMD Radeon HD 7850 Overclocked Video Card - GDDR5 2048MB 256-Bit - 920 / 5000MHz Clocks - DVI, HDMI & 2x Mini DisplayPort - AMD HD3D - AMD Eyefinity 2.0 - CrossFireX - DirectX 11 (11200-01-41G) [$269.00]
1 x 17040390 - Samsung SH-222BB/BEBS Internal 22x DVD Burner - SATA - OEM - Black [$19.99]
1 x 34040684 - Antec HCG-750 High Current Gamer 750W Power Supply - ATX12V v2.3 - EPS12V v2.91 - 80+ Bronze Certified - NVIDIA SLI & AMD CrossFireX Ready - 135mm Cooling Fan (HCG-750) [$135.00]
1 x 39090362 - Microsoft Windows 7 Home Premium - SP1 - 64-Bit - DVD - Single Pack - OEM (GFC-02050) [$99.99]
1 x 18020624 - Cooler Master Hyper 212 EVO - 120mm Cooling Fan - Intel Socket LGA2011/1366/1156/1155/775 & AMD Socket FM1/AM3+/AM3/AM2+/AM2 - (LGA2011 with Bracket*) 9 - 36 dBA - 600 – 2,000 RPM (PWM) (RR-212E-20PK-R2) [$39.00]
System Total: $1,206.93 (inc. Build Fee)
http://www.mwave.com.au/ any part suggestions have to come from here, also trying to keep it around the 1200 mark
4 answers Last reply Best Answer
More about will part pick work together advice changes
  1. Best answer
    That build will be just perfect and I couldn't have picked anything different , I have actually posted that build several times for someone looking for a build in that price range. The computer will be even better later on when you add the SSD and the second 7850. I realize the prices are a little higher because of where you live.
    yeah i was looking at newegg prices and it made me sad hahaha but its different economies thanks, my new computer is incoming yay
  3. Best answer selected by Bazuzu.
  4. Hope you have fun putting it together and enjoy your new computer , it's sounds like you can't wait to get your hands on it.
New Build Systems Product
