I'm a novice builder that is planning a new rig. To give you some idea of me, I'm a mechanical engineer with grey hair; which means I have a much better aptitude for computers than your average Joe but I'm far from a computer engineer. Some guidance and a point in the right direction and I can figure stuff out pretty well. In short, I know just enough to be stupid and dangerous, which is why I'm here.
To give you an idea of what I want to build. My budget is around $2,000. I won't cry if I go a bit over but I don't want to waste money either. The primary usage will be gaming which will probably include some video capture and editing, the usual home/office type stuff, entertainment, and possibly some 3D CAD (Solidworks). So ultimately the system will I expect include
a monitor, a TV,
I'm planning the build around an Intel Core i7-3930K Sandy Bridge-E 3.2GHz CPU. Since I'm new to building I'm not planning on overclocking right out of the box but I may want to do that further down the line.
First up for discussion is motherboards. I've narrowed my choices to
ASUS Sabertooth X79 at $319
Intel X79SR at $319
Intel X79SI at $259
ASRock X79 Extreme 4 at $224
Below are my naive pros & cons. Please help me decide on the mobo first, then we'll move on to other components. If you want to suggest a different board, feel free to mention it and give me the reasons why - which should be more than "because it's great".
Sabertooth:
Pros:TUF aspect and their attention to heat, Turbo Boost 2.0, Digi+Power, SSD Caching, Firewire, Optical, 5 yr warranty
Cons: NewEgg reviews point to reliability concerns (but it has longest warranty). The max memory speed is also a bit slower but that's minor. I'm a bit leary of whether this board requires more expert builder than I am. Price.
X79SR:
Pros: WiFi, Bluetooth, 10 Channel Sound(7.1 +2), Firewire, Optical, Intel Reliability/Stability (?)
Cons: Price
X79SI:
Pros: Price, Bluetooth, Intel Reliability/Stability (?)
Cons: Basic Sound, Only (2) 6 Gb/s drives
ASRock X79
Pros: Price, ASRock has good ratings/review/awards, ASRockFAST technologies but they seem more related to 32 bit, is it just marketing hype.
Right now I'm leaning towards either the Sabertooth or the X79SR and the X79SR has the edge because of my experience level, the sound, WiFi and Bluetooth.
Thanks for your help. I'm really looking forward to going through this build.
Jetson
a monitor, a TV,
Intel X79SR at $319
Intel X79SI at $259
Sabertooth:
X79SR:
Cons: Price
X79SI:
ASRock X79
Jetson
