First Build Help
Last response: in Systems
Hi guys this is my First build, I am going to get the parts soon, but before I do i would like to check if all of the parts are compatible, I would also like to check if my Psu is big enough, and if my motherboard has all of the needed wires, my specs are listed below...
MBU: MSI 870S-C45 (FX) Mainboard AMD
CPU: AMD FX 4100/ 3.6GHz Quad Core Processor
RAM: Corsair XMS3 4 GB Memory 2 x 2GB RAM
GPU: XFX HD 6790 1GB Graphics Card
PSU: OCZ Technology 500W CoreXStream Series Power Supply
Case: 777 T-Bird
Fan: Arctic Cooling F12 (120mm)
Thank you for your responses
Case: 777 T-Bird
More about : build
Related ressources
- CPU and GPU can't decide for a first time gaming build . please help - Forum
- First New Build . I need your opinions and help - Forum
- Need help picking components for my first build - Forum
- Need help build the first gaming pc - Forum
- I'm gonna build my own gaming pc for the first time, need help . - Forum
RaefD said:
because we have not gone to college or university, the majority haven't even started most of our GCSE's, that's my theory anyway
, Thanks though Big Troll, do all of the parts that I have now will work together, without issues?, also are all of the cables needed included?No porblemo! yes all the cables are included. your motherboard (if new) should come with 2-4 Sata cables. 1 Sata cable for the optical drive, 1 for the HDD. Look at the mobo pictures to see how many sata cables they provide. Your PSU has a PIC-E 6/2 Pin connector so that supplies your GPU. Everything will work fine as long as they are not DoA. You're good to go.
are you serious it performs about the same to a i3?
http://www.tomshardware.com/reviews/gaming-fx-pentium-a...
2670074,28,1180229 said:
are you serious it performs about the same to a i3?http://www.tomshardware.com/reviews/gaming-fx-pentium-a...[/quotem
I3 gets on average about 11% more than the FX-4100.
Using the i3 as a comparison, not saying they're on par.
http://www.tomshardware.com/reviews/fx-4100-core-i3-210...
Related ressources:
- ForumNeed help finalizing the parts in my first build
- Forum$500-$600 First Time Budget Gaming Build Help
- ForumHelp on first build
- ForumHelp me build my first gaming pc.
- ForumFirst Time Build . Need Help /Advice.
- ForumFirst time computer build *need help *
- ForumMy official " help me build my first computer!" thread
- ForumNeed help with first build (budget)
- ForumHelp me improve my first build
- ForumHelp with first build
- ForumNoobs First build , help please (:
- ForumNeed Help . First HTPC Build Don't know where to begin
- ForumFirst Real Build . $600-800. Have Rough Idea.. Help ?!
- ForumOpinions and help on First Build
- ForumFirst PC Build -Need General Help +Tips.
- More resources
