Need to upgrade power supply and ram??
Here is what I have, below is the readout from my system summary. I also have a ide Hard drive that I am running windows xp off of( it has my pro tools on it). I have since purchased a XFX R6770 Core Edition video card so I could utilize a dual monitor setup. I would like to in the future add another optical drive as well as another sata hdd. What would you suggest for a new Power supply. I believe the one I have isn't going to have the power requirements for more drives, as well as cables. I am also looking to upgrade my ram to 8 or even 16GB, what would you suggest for that??
1 x GIGABYTE GA-MA790GPT-UD3H AM3 AMD 790GX HDMI ATX AMD Motherboard
1 x AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGIBOX
1 x OCZ AMD Black Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3BE1600C8LV4GK
1 x SAMSUNG Spinpoint F3 ST1000DM005/HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1 x LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name
System Manufacturer Gigabyte Technology Co., Ltd.
System Model GA-MA790GPT-UD3H
System Type x64-based PC
Processor AMD Phenom(tm) II X4 955 Processor, 3200 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Award Software International, Inc. F3, 9/16/2009
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
Time Zone Central Standard Time
Installed Physical Memory (RAM) 4.00 GB
Total Physical Memory 4.00 GB
Available Physical Memory 830 MB
Total Virtual Memory 8.00 GB
Available Virtual Memory 2.52 GB
Page File Space 4.00 GB
Page File C:\pagefile.sys
6 answers Last reply
More about need upgrade power supply
  1. Any matching DDR3 1600MHz ram will work. What is your current PSU? HDD pull very little power and usually are not a reason to upgrade PSU.
  2. Well 8Gb ram will be ok. For gaming u dont need 16 Gb ram.
    And about the PSU
    Antec Vp450W or Cx 430W V2 will be ok with your rig.
    If u plan to add GPU when add $ and get XFX 550W
  3. Which PSU you currently have again? Try this
    http://images10.newegg.com/BizIntell/tool/psucalc/index.html?name=Power-Supply-Wattage-Calculator
    Newegg still has this for $50. It's a steal considering 8GB is like $45 already.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231489
    And get a 650W in case you decide to get a gtx 680, probably need more wattage if you want sli/cross fire.
    Newegg still has the corsair psu series on sale
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=corsair+650w&x=24&y=18
  4. 8gb is fine for now, how ever, if you want to get into pro level Video Editing, it might be a good idea to buy 16... But you could go 8gb then 16gb later. IMO, for best perfromance, go with a 750w, they're the same price as the 650w.
  5. My PSU is a Thermaltake W0146RU PS
    Here is the original thread that I used to help pick the components way back when.
    http://www.tomshardware.com/forum/278639-31-pick-parts-photoshop-internet
  6. Therotically your PSU is big enough but is not a quality unit so swapping to 500watt + quality unit would make sense. http://us.ncix.com/products/?sku=59615&vpn=P1550SXXB9&manufacture=XFX&promoid=1257
Power Supplies Components Product
