My build won't even POST! Please help!
My new build won't even post after I've put it all together. I push the power button and get absolutely nothing.
I did get the fans to spin one time. There was no RAM or hard drives plugged in. Once I plugged in a stick of RAM it wouldn't start again. I took out the RAM and it still would not start. Right now no matter what I plug in or take out, it does not work.
These are my specs:
The Sandy Bridge i3 2120
Cooler Master Elite 371 Case
I've tried an Ultra 450W Power supply (http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=1147665&CatId=1078) and a Thermaltake 430W PSU which I got from Best Buy because I suspected the psu was the problem.
BIOSTAR H61MGC Intel H61 Motherboard
1 stick of 4GB Visiontek RAM - 240 Pin
I'm reusing a 200GB Seagate Hard Drive from an old laptop
XFX HD-677X-ZNLC Radeon HD 6770 Video Card
Stock CPU Cooler
Things I've already tried:
First, I did absolutely everything in this thread:http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems . Nothing worked.
Swapping the PSU. I've tried both Ultra 450W Power supply (http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=1147665&CatId=1078) and a Thermaltake 430W PSU which I got from Best Buy because I suspected the psu was the problem. This resulted in no change. I know it's a possibility that I just recieved two dead power supplies so when I go to return the Best Buy one I'll buy a new one.
I might try a power supply with a lower wattage. Could somebody please help me? I'll post pictures if necessary.
Also: I'm sure that nothing is shorting the motherboard because I tried breadboarding it on top of some styrofoam.
Thanks.
5 answers Last reply
More about build post help
  1. make sure you use the case stand offs.
    http://www.youtube.com/watch?v=rqqxqE6iswU
    check that the i\o shield not shorting out the mb.
    make sure the 24 pin and the 4/8 pin atx plug in connected.
    it be near the cpu or one edge of the mb.
    I tried breadboarding it on styrofoam so I'm sure nothing is shorting out the motherboard. Both the 24 and 4 pin atx plugs are connected.
  3. what the part number or info of the ram..most new intel mb need 1.5v ram ddr-3 10666-1600 speed for stock. on some mb the 1800 and faster ram wont work. also check that there no bent pins under the cpu and the cpu seated.
    This: http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=1636640 is my RAM. I don't think that the ram is the problem though because I would hear a beep code at least. It should still work without ram installed. I checked the cpu as best as I could, it looks like there are no bent pins.
  5. You should make sure you didn't short the motherboard itself.
Homebuilt Systems
