How does a water cooling system work
Could someone please tell me how a water cooling system works or any possible ways how to make a homemade water cooling system?
-e-coli
7 answers Last reply
More about water cooling system work
  1. http://www.tomshardware.co.uk/forum/277130-11-read-first-watercooling-sticky
    Please don't double post and read this sticky as previously directed :)
  2. In making of a homemade system there is high risk of damage you can do, so why do wont to make one and do you have the means to make one.
    The system use water because water has a higher thermal conductivity than air - it can move heat faster than air can. Water also has a higher specific heat capacity. It can absorb more heat before it starts to feel hot. This is good because you can transport the heat somewhere far from the components.
    Thanks for reminding me not to double post.
    But I double posted because this one is in the wrong section.
  4. No problems. Just close the thread if it's wrong. Hope you find what your looking for. Water cooling is a great hobby but don't expect it to be cheap ;)
  5. Thanks for telling me that. But where do I exactly close the thread?
    -ecoli
  6. I'll be honest, I've never created one so I wouldn't know. Sorry.
  7. The purpose of a watercooling setup is exactly the same as your central heating system, to collect heat from a heat source and tranport it to somewhere where it can dissipate that heat. It can do this more efficiently than an air cooler but it also has it's downsides e.g. disrupted airflow within the case, leaks.
    Reservoir/Header Tank -> Pump -> Heat source (cpu/graphics card) -> radiator -> Header tank/Reservoir
Water Cooling Components
