Are these parts good and all compatible? I will add a screenshot aswell. All parts are found on Frozen CPU
Swiftech MCP35X 12v PWM Controlled Water Pump - White
Select G 1/4" Fittings (Qty. 2): 3/8 x 1/2 TFC Compression Fitting ($7.98)
$107.97 $107.97
Bitspower 5.25 Bay Reservoir - Acrylic - UV Blue Seals (BP-WT525AC-CLUVBL)
$62.97 $62.97
PrimoChill ICE Non-Conductive Liquid Cooling Fluid (32 oz.) - Invisible Blue $19.99 $19.99
Bitspower Summit EF CPU Liquid Cooling Block - Intel LGA Series - Ice Blue Acrylic (BP-WBCPUIAC-CUMBKIBL)
$87.97 $87.97
2.5 Meter (8 feet) Feser Tube Active UV Hose - Retail Packed - 3/8" ID (1/2"OD) Anti-Kink Tubing - UV Light Blue $14.95 $14.95
Swiftech MCRx40 "Quiet Power" Dual 140mm Radiator - Black (MCR240-QP)
$72.93 $72.93
NZXT FZ 140mm x 25mm LED Airflow Fan Series - Blue LED
$107.97 $107.97
$62.97 $62.97
$87.97 $87.97
$72.93 $72.93
