Modem problems again, SR 71 Black Bird Plz HElp
Hello, we went through this October 2011. Sorry to be a bother. I'm old (I guess) can't remember. When I try to install the drivers you gave me last year, I get the blue error screen. WHat am I doing wrong? I go to the PCI Simple Communications and try to install there. To refresh your memory:
Driver for PCI simple communication controller for Win XP Please and I am running a HP Pavilion a1200y. Modem Ven is 14F1 Dev is 2F20. PCI Database.com returns:
Device Id Chip Description Vendor Id Vendor Name
0x2F20 SoftV92 Data Fax Modem with SmartCP 0x14F1 Conexant Systems, Inc.
Can't find a driver that works? Please and Thank You.
14 answers Last reply
More about modem problems again black bird help
  1. http://members.driverguide.com/driver/detail.php?driverid=575484
    What happened that the modem stopped working or needs the drivers reinstalled again?
  2. http://www.conexant.com/support/files/HSFp_WinXP.zip
    Unzip the file and install from the device manager.
    I had to restore to a previous time and lost the modem in the process
    I have tried to install the /HSFp_WinXP.zip and It doesn't work. I get the blue error screen. Reboot in safe mode to remove or disable.
    I thought if I simply point to the HSF drivers it would recognize the modem and install. Instead I must chose Modem from the list of hardware I want to install. I think therein lies the problem.
    SR-71 Blackbird, Could please tell me the correct way to install from the device manger?
    Thank You, Warren
  6. I go to Control Panel and select phone and Modem. Then I open modem to select new hardware. I point to the .inf file, in this case GENHSF5.inf but it doesn't install. I try to install with HFXsetup.com. Doesn't work?
    SR-71 Blackbird , Here is where I am. The modem installed without a problem. When Fax Monitor pops up, the blue error screen comes up.
    Thank You,
    Warren
  8. Are there any other issues showing in the device manager.
    No Sir it looks good...not sure if you know the modem is in there but if I enable it then when the fax monitor starts, I get the blue error screen. It seems the modem itself is fine something in the Fax software.
    Thank You
    Warren
  10. Okay, I went into add remove progs and disabled Microsoft Fax Services and all is well. Maybe I should another fax program? Do I still have to enable MS Fax Service?
  11. I would leave it alone.
  12. I wanted to send a fax and that is when this started. Thankyou so much for generous help. The pleasure is mine
    Warren
  13. Have a great weekend.
PCI Modem Components
