I'm not sure if this is in the correct part of the board, but I've been having an issue where if the clothes washer or dryer are on (which are hooked up to the wall directly opposite to my computer), I get checkerboard effects on my display which results in a graphics TDR which mostly will happen if the computer is under load, but occasionally also happens even on idle or web browsing.
If I'm trying to power the computer on when the washer or dryer is on, these graphical glitches happen right away and sometimes it doesn't even boot, or BSOD.
Is this an issue with filtering? Is there ground noise that is interrupting the power enough to cause these issues on my computer? It's already connected to a surge protector, and I've thought about getting a UPS but I thought I'd get some other people's opinions since I don't know much about this stuff. Thanks in advance!
My computer specs are in the sig. Let me know if I need to provide any more information.
UPDATE:
Yesterday was my dad's birthday so I couldn't do any troubleshooting, but here is an update.
This morning before heading out to work, I made sure the washer, dryer, and stove were all turned off and powered on my computer. Post was normal, but after that i got white checkerboardish effects and then it blue screened. On the auto-reboot after the blue screen, the graphics were all messed up even on the post so I turned it off and left for work.
So it turns out this issue happens on cold boot, even when the washer and dryer isn't on. Could this mean there is an issue with my power supply? Would there be any way to check if everything is ok with the PSU using a multi-meter? I'll try plugging in the comp near one of my tv's (which is on the other side of the house from the laundry room and computer room) and see if these problems continue.
It's weird because sometimes I'll be able to turn the computer on, run kombuster, games like battlefield 3 etc. just fine. But then sometimes it'll blue screen on boot with the graphical glitches, checkerboard then TDR when the graphics card is under load, or TDR even while web-browsing or even idle.
My PSU is a TX850 v2. I'm completely lost here and I appreciated you guys trying to help me.
UPDATE 2:
Video of the issue:
http://www.youtube.com/watch?v=d6szKyNKsv0&feature=youtu.be
UPDATE:
UPDATE 2:
Video of the issue:
