Okay, so I've been watching videos and learning about hardware as much as I can and I think I've got something decent. My goal is to be able to spend the least amount of money possible while being able to run games and high-max settings. The only game that I really play right now is SWTOR. I want a computer that has little to no lag with some good setting running. I'm completely new to computer hardware and don't really understand that much; so I came here. I have quite a bit of questions to ask. Are the parts I picked compatible with each other. Are there any other parts that will lower the price, but not affect performance? Are there components out there that would make SWTOR run better with out adding too much more money. Are there any other "trusted" websites that sell the same hardware for cheaper? Is this build good enough to run SWTOR on moderate-high settings. Also, I'm not quite sure about the power supply, HDD, or SSD. Are there any other that you could recommend that are perhaps cheaper? Feel free to recommend an entirely different build that could save me money, but still have a good performance rating. Thank you!
Processor: (Intel Core i5-2500K Sandy Bridge 3.3GHz)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Motherboard: (BIOSTAR TP67XE)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138317
Power Supply: (OCZ ModXStream Pro 600W Modular High Performance)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
Computer Case: (Rosewill CHALLENGER Black Gaming ATX Mid Tower )
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Memory: (G.SKILL Ripjaws X Series 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231492
HDD: (Western Digital RE4 WD5003ABYX 500GB 7200 RPM 64MB Cache SATA 3.0Gb/s 3.5")
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136697
SSD: (Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive)
http://www.newegg.com/Product/Product.aspx?Item=20-148-441
Video Card: (ASUS ENGTX550 TI DC TOP/DI/1GD5 GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121434&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullIn
"Wishlist" Video Card: (ASUS HD7850-DC2-2GD5 Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121623
Once again thank you for helping me on my process to build a gaming computer!
