D dragonx47 Honorable Apr 13, 2012 16 0 10,510 May 23, 2012 #1 If I overclock the core anywhere above 850 MHZ, the screen goes black, then reappears with a message saying the driver failed. This happens again as soon as I open another app. My PSU is 480W. Could it be the problem?
Sunius Splendid Dec 19, 2010 9,588 0 31,960 May 23, 2012 #2 You can't really overclock that much for HD 6670. Upvote 0 Downvote
D dragonx47 Honorable Apr 13, 2012 16 0 10,510 May 23, 2012 #3 AMD Overdrive allows up to 960 mhz for the core clock ,but I can only go to 850 without the driver failing. Upvote 0 Downvote
Sunius Splendid Dec 19, 2010 9,588 0 31,960 May 23, 2012 #4 Well, VW Golf has 260 km/h on its speedometer too. Do you think it can reach it? Upvote 0 Downvote
J_E_D_70 Splendid Mar 21, 2012 7,294 59 30,290 May 24, 2012 #5 Right. Each card has a limit even within the same make and model. Also, that program is probably generic across all of their cards. Upvote 0 Downvote
