Hello everybody, i'm sorry for my english but i hope you'll understand it and you'll be able to help me.
My configuration is:
Cooler Master Silent Pro 700 Watt
Cooler Master HAF 932 Advanced
Asus P8P67 EVO Rev 3.0
Intel i7 2600k (no overclock)
AMD/ATI Sapphire 6970 2GB (no overclock)
Corsair Vengeance 8GB High Profile 1866mhz XMS
2x Seagate Barracuda 1TB Sata 3
Xonar D1 PCI
LG Flatron 22 Full HD
Windows 7
My problem is:
When i try to boot my pc i get a solid red VGA LED, 1 long beep + 3 short beeps and no video signal.
These signs show a problem with videocard, but i think the problem is about the Power Supply.
First time i had this problem i just unplugged/plugged the VGA and the PC worked fine for one whole day; then after shutting it down i had the same problem again. I've changed 6+2 pin cable and it worked again for few days. Then today i had the same error and nothing solved it.
I've tried moving VGA to the other PCI-E slot, i got the same error. Then i've decided to measure voltages coming from the PSU, and i noticed these values:
6 pin = 12V (correct)
+2 pin = no voltage
I wonder if the no voltage measured in the +2 connector is correct or if there is some problem. I did the same measure with both 6+2 cables i have and the result is the same.
Thanks for your replies, if you think the problem is about VGA and not PSU i ask mods to move this topic in the correct section.
Xonar D1 PCI
Windows 7
My problem is:
+2 pin = no voltage
