Well I've picked out some parts, but I'm looking for advice on if the build looks good, and if anyone would change anything. I already have a disc drive, HDD and a monitor, so the following are the parts I will need to buy. Trying to keep it under 800 but if it's really worth it I may go a little higher. The goals are to be able to play games like total war on high settings (not ultra but pretty nice) without a struggle.
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard.
AMD FX-8150 FX 8-Core Black Edition Processor Socket AM3+
Corsair Hydro Series H80 High Performance Liquid CPU Cooler
Corsair Vengeance 16 GB (2x8GB) DDR3 1600MHz PC3 240 Pin DIMM Memory
CORSAIR Enthusiast Series TX750 V2 750W ATX 12V 80 PLUS BRONZE Certified Active PFC High Performance Power Supply--- I know this is a bit much, might get a lower wattage one but I just wanted to make sure I had enough power.
The graphics card is the thing I'm having the most trouble with. Not sure which one will give me the best bang for my buck.
ANY help and advice would be greatly appreciated!
