I was wondering if all of these parts I am getting for a budget PC build are compatible, and also if I will need to get a better power supply or case or anything.
Case: Antec GS one Illusion,
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129182
HDD: WD Caviar Blue, 500GB,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
GPU: Sapphire Radeon 7750,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102985
PSU: SeaSonic M12II 520W modular,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151093
RAM: G-Skill Ares 2 x 4GB 1600MHz,
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544
CPU/Motherboard: Intel i5-3570K (3.4/3.8 GHz) and ASRock Z77 Pro4 , COMBO
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.984223
DVD: ASUS 24x DVD burner,
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
OS: Windows 7 Home Premium OEM,
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Also, is there anything else I will need to purchase to get this computer running? Thanks a lot!
