Starting building, need some help
Last response: in Systems
Hi i am in the middle of building my first PC at first i had all the components and wires plug in but when i turned on the PSU nothing happened, the fan in the PSU didnt even move or make noise, is it suppose too? nothing else in the computer moved or twitched when i turned the PSU, does this mean my PSU is dead?
More about : starting building
moondawg009 said:
case header?
Case header = tiny pins on the case that connect to a part on your motherboard, it's what allows the computer to turn off, reset, and powers the audio and front USB functions on your case.
Related ressources
moondawg009 said:
shoulndt the psu activate without that and the motherboard?
No - your build will not turn on without those pin headers connected to your motherboard. If you're testing your PSU to make sure it works, you still won't be able to unless you had professional testing equipment.
moondawg009 said:
okay theres the power led, power SW, reset sw, H.D.D LED, HD audio, AC'97 USB? are these what you mean?
Yes - those must be hooked up to your build for it to function. There should be a layout guide in like the first 10 pages of your user manual.
Believe me - it's my least favorite part of the build but it has to be done. :lol:
moondawg009 said:
there are two power LED ones one has two pins the other has 3 also the manual dosent specify where the USB and the HD audio and the AC' 97 go
I don't know what motherboard you're using but there should be at least 2 x USB 2.0 headers and 1 x HD audio header that should be clearly labeled. The AC '97 header shouldn't be used for the most part.
you can also just short the two pins on the motherboard (page 2-13, JPF1 diagram) to get it to start instead of fooling around trying to plug in the case power.
http://youtu.be/d_56kyib-Ls
look at your users manual and it will show which pins are power, and then short them with a screw driver or with a paper clip.
You also only need to plus in power to make the computer POST.
moondawg009 said:
i dont think my MOBO can do that and the power switch or whatever on the MOBO isn't labeled in the manual
Most Z68 and Z77 motherboards have an LED light that enables it to display POST messages, but that can only happen if the proper power connectors are heading to it.
every motherboard can do this. its just like using an actual plug. and in the diagram I listed, it says "power switch" and links -8 and +6 pin. short those with a screw driver and it will work.
moondawg009 said:
everything is moving and stuff except for my cpu fan is not moving, it is plugged in is that normal?
No, that is not normal.
Make sure you have the CPU fan plugged into the right fan header.
Are you using the stock Intel heatsink?
moondawg009 said:
Having trouble connecting to the internet, i have a hard cable connected to my modom and the computer is there some secret i am missing
You have to input your modem's IP address into the network settings control panel.
moondawg009 said:
i got the internet to work, one other thing when i go into device manager it dosent recognize my radeon 6870 is just says Intel HD graphics family
Have you downloaded the proper drivers?
All the cables I posted, their is a plug for them. The options are VGA, HDMI, DVI, and Display port. Your monitor, depending on the model, can have any combination of these ports. What model do you have?
Most monitors come with VGA and DVI, then either using HDMI or display port. Thought the high end monitors has all.
i typically dont read the newegg reviews but this is what people are saying
-DVI-D to VGA typically not possible. This adapter will not work for what you think it will do.
-Really i don't even know if it works or not because DVI-D can't be converted to VGA (gfx card to monitor)
just want to be sure it will work for what i am using it for, also my gfx card has two DVI ports i believe i am assuing one is DVI-d and the other is DVI-I?
Ask the community
