Got my new storm trooper today, including a OCZ 600 watt and a Asrock 970 Extreme3.
Been doing cable management for a few hours now, connecting everything etc.
But, there's this one issue.
When I press the fancy big black button on the top of the case, it doesn't power up.
Yes, the PSU switch is on.
No, I'm not sure if the system panel is connected right.
It says pwrbtn for one pin, then the one on the left is pwr led - and the other one is ground.
I'm not sure how to connect the whole fan stuff as I never worked with fan controllers before, I did connect all the fans and all those things.
Also, a quick response would be appreciated as it's getting quite late now
Specs:
AMD Phenom II X6 1090T
Corsair 8GB DDR3 1600
Radeon HD 6790
OCZ Modxstream pro 600 watts
Asrock 970 Extreme3
CM Storm Trooper
Specs:
Radeon HD 6790
Asrock 970 Extreme3
CM Storm Trooper
