I'm not sure where on this forum to ask these questions, so if a moderator knows of a more appropriate section...
What do you guys use to clean the outside of your cases, both desktops and laptops? I heard a guy on a podcast recently say he uses some sort of auto leather conditioner/cleaner on his customers' cases. Says it puts a nice shine on 'em. It seems that some sort of auto interior cleaner would be good to revitalize the exterior, like Armor All or Meguiar's vinyl & plastic cleaners. I dunno about what that would do for painted metal exteriors. Does anyone here use stuff like this? Any other ideas?
Also, I know that you should avoid glass cleaners with ammonia in them, like Windex, to clean lcd screens. Any of you use some other non-ammonia based cleaner for lcd screens, like Glass Plus? Specifically, I'm referring to any commonly found cleaner that isn't marketed as a specialty item for lcd/plasma type screens. I see that there's a product called "Invisible Shine" that says it evaporates 100% and leaves no residue, though I cannot find whether or not it contains ammonia, so I'm not sure if there's anything in there that would have a non-desirable chemical reaction with the screen materials.
