Solved
Will Electrical tape prevent short circuit
  • Power Supplies
  • PCI
  • Short Circuit
  • Components
Last response: in Components
November 28, 2012 7:46:53 PM
I just recently bought a pci fan and have found it rattles a bit when installing and I am afraid it will short my motherboard if it hits against it. Will applying electrical tape to bottom of pci fans metal guard prevent this and will it hold. Have not installed it yet because of this. Thanks for the replies in advance.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1683...
More about : electrical tape prevent short circuit
a b ) Power supply
November 28, 2012 10:23:36 PM
Hi :)
My shops sell those type, just screw the top screw in and it SHOULD NOT rattle at all...if it does return it...its faulty...
All the best Brett :)
m
l
a b ) Power supply
November 29, 2012 12:00:45 AM
this bracket screw the same way you do with a pci-e graphic card ,that goes to the back of the case extension slot
m
l
November 29, 2012 1:26:34 AM
So it should not interfere with my motherboard or should I still add electrical tape to be safe?
m
l
Best solution
a c 157 ) Power supply
November 29, 2012 1:36:48 AM
No need to do anything special.
If you set the screw holding it snug, it should not rattle.
Look carefully to see that the bottom tab of the fan is sitting in the notch of the case so that it does not move around.
The fan guard is probably plastic, but no harm would come with tape.
November 29, 2012 2:18:47 AM
Best answer selected by generalissimo.
m
l
