Are these two parts compatible?
  • Radeon
  • Computer
  • Video
  • Compatibility
  • Graphics
  • Product
May 25, 2012 12:51:22 AM
just built a computer and got this video card
and I'm trying to make sure it was compatible with this motherboard
More about : parts compatible
May 25, 2012 1:02:11 AM
yes it is if your not getting any video check to see if the mb has onboard video and that is working. sometime the onboard is set as first device. also check that you have the video car in the blue video card slot and have all the power cables it needs plugged in some video cards new two 6 or two 8 pin. another issue with amd mb is check the cpu history some amd mb wont boot with new cpu intill the mb bios is updated...sometime you need an older cpu to do this.
m
l
May 25, 2012 1:04:57 AM
Sure. It will work. That is a nice motherboard & can even accomodate 2 of those video cards when you want to upgrade in the future.
Have you bought both parts?
m
l
May 25, 2012 1:09:36 AM
Your fine mate it's compatible your motherboard features Quad-GPU SLI and Quad-GPU CrossFireX Support! ;)
m
l
May 25, 2012 1:18:15 AM
His mobo doesn't have Onboard Video Chipset
m
l
