Hey guys, so this is my first time ever putting together a computer from parts and not bought a prebuilt system.
My budget is $800.00 for this build
I would like to ask the community if all these parts will work together and there is no conflicting issue.
Most of the parts I have chose to be used are parts used in the $650 gaming build made here.
Link: http://www.tomshardware.com/reviews/build-gaming-pc-overclock,3159.html
The only parts I opted out and decided to change are the processor and the video card. So here are the parts.
Parts:
--Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147123
$29.99
--Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820313102
$21.99
--CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
$219.99
--Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813128539&Tpk=N82E16813128539
$69.99
--Hard drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
$74.99
--Video card http://www.newegg.com/Product/Product.aspx?Item=N82E16814127663&Tpk=N82E16814127663
$239.99
--Optical drive http://www.amazon.com/LG-Electronics-Super-Internal-GH22NS90B/dp/B005S0YK1W/ref=cm_cr_pr_product_top
$23.50
--Power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200
$59.99
Total cost (This isn't including rebates): $740.43
So any insight on any problems or maybe opting out and buying other parts from what I stated is what I am looking into. This build will be used mainly for gaming.
Thanks in advance guys!
Parts:
$29.99
$21.99
$219.99
$69.99
$74.99
$239.99
$23.50
$59.99
