Surround Sound with Regular headphones?
mzisman4
25
I was about to pick up a gaming headset for the virtual surround but read around and saw that no special headset is needed. Most threads I've read through say to get a sound card but I was hoping to be able to use some of my existing mid-fi equipment to get it working. I don't currently have a dedicated sound card. I've been a member over at Head-Fi since high school and have a decent setup for my music listening. I'm only interested in the surround for playing BF3--a recent addiction. The computer is not used for movie viewing.
What is the best way for me get surround? What would sound best with my existing equipment?
Comp:
Mobo: G1.Sniper m3
CPU: 3570k
Graphics: Gtx 680
Memory: 8gb
Audio Stuff:
Headphones: AKG k240, AT ESW9, Stax Lambda, Stax SR-30
Dac: JDS ODAC (usb)
Amps: Hotaudio Thunderbolt, SRM-1/mk2 (Stax)
Current setup:
USB->ODAC->one of the amps->headphones
mzisman4
25
By amps do you mean receivers? None of my headphone amps do decoding.
Is the most common thing with Dolby Headphone support a sound card?
If I got a sound card, should I still use the ODAC via usb? Would sound be better without it? Would I still need an amp to drive the headphones?
I'm not very familiar with what sound cards do--are they decoders? amps? both?
Well, a few things:
1: Most soundcards support some form of Virtualization. Usually Dolby Headphone, though Creative uses CMSS-3D for the same effect.
2: Some soundcards have a dedicated headphone amp built in. That would (in theory) remove the need for the amp and ODAC.
There is an X-Factor here: I've heard a few people claim that BF3 doesn't work that well with Dolby Headphone. I can't speak personally (it seemed OK the one time I tried it) though. Might want to check up on that.
mzisman4
25
Thanks for the help. I have a post in Head-Fi probing for ODAC surround possibilities.
I just want to avoid buying more hardware for one FPS game.
Will report back because if there is a solution, the ODAC would be a great budget alternative for gaming audiophiles.
