How to check the pump speed of corsair H80
Last response: in Components
Related ressources
- I7 3770k with Corsair H80 : idle@ 34 degree, GOOD? - Forum
- High temps when overclocking i7 3770k with corsair h80 - Forum
- Very pleased with the Corsair H80 - Forum
- Corsair H80 Has 3Pin Fan & my MB has 4Pin Fan - Forum
- Corsair h80 problem - Forum
Related ressources:
- ForumH80 pump speed regulation
- ForumHow loud is Corsair 's H80 cooler?
- ForumHow to check if the corsair h60 pump is working at 100%
- ForumQuestion about corsair H80
- ForumH80 died?
- Forum2500k + Corsair H80 very hot load temp?
- ForumCorsair H80 not cooling + black screen when accessing BIOS on P9X79
- ForumCorsair H80
- ForumHeat troubles with an I2600k + Corsair H80 liquid cooler
- ForumWhat fans are better than the corsair fans that come with the h80 ?
- ForumFX-6200 vs FX-6300?
- ForumHow does this preform?
- ForumHow do i chose a ups?
- Forum[Solved] Fractal Design Define R4 Or Corsair Obsidian 650D
- ForumCorsair H80 temps too high?
- More resources
Read discussions in other Components categories
) But you'll still get good performance out of it and your chip.
