well i get that u need a 4 to 8 pin connect but i mean i only have one 4 pin connecter and thats taken by the atx cpu plug in which idk what it does so idk if i should mess with that or get a new connecter to connect to my power supply
gateway dx4870-ub20p i got a 620 in there rite now but im trying to put a 560 gtx as upgrad u think theres adapters that can fit becz i got no more money for a new psu
As ish416 said, they're molex adapters you could buy, but if your Power Supply didn't have the necessary connectors for a GPU, it means it can't support a GPU that requires those PCI-E 6 or 8 pin connectors.
Even if you get those adapters, your PSU may not support the video card itself and it could damage your hardware.
why would they have adapters if u cant connect it to ur psu anyways and mess everything up..?
