Router 1: I have a WRT120N wireless router connected to the Internet. It has IP 192.168.1.1 and DHCP is enabled with address range 192.168.1.100 up.
Router 2: I have a WRT310N router connected to the LAN via LAN port to ethernet jack in the wall (not WAN/Internet port). It has ip 192.168.1.2 and DHCP is DISABLED.
All the devices on my network can see each other. Devices connecter to router 1 can see devices connected to router 2.
The problem is, devices connected to router 2 cannot get to the Internet. I verified clients connecting to router 2 are assigned the same DNS addresses and the same gateway 192.168.1.1 as the clients connected to router 1. But for some reason router 2 doesn't know how to router Internet traffic out through router 1?
I tried plugging the LAN cable into the Internet/WAN port on Router 2 but then devices on Router 2 can no longer see devices on Router 1.
I've seen discussions of setting up router 2 on its own subnet: 192.168.2.1 instead of 192.168.1.2 but then supposedly devices on router 2 will still not be able to see devices on router 1.
I'm guessing router 2 can't access the Internet because it is default configured to send Internet traffic to the Internet port, no t the LAN port.
Any suggestions on how to configure it so all devices on both routers see each other and router 2 devices can get to the Internet is greatly appreciated.
