Graphic card problem
Related ressources
Graphics card Master
saurabhsethi9 said:
I am just planning to buy a gts 450 nvidia graphic card i have a 450w psu but i have only 1 connector can my graphic card work if i split 4 pin into two 4 pin. wil it work??
If your PSU have the 6PIN PCIe connector, you do not need to split it. It should fit right into the graphics card.
saurabhsethi9 said:
so i can connect black coloured molex to graphic card??
No. The PCIe power requirement of the 450 is 1x6PIN PCIe & not MOLEX.
saurabhsethi9 said:
so i dont need a splitter?
No. You do not need to split anything.
i dont have 6PIN PCIe connector
I see. I guess I got confused with your original post.
If you do not have PCIe, this is what you need:
http://www.google.com/imgres?imgurl=http://www.atxpower...
http://www.google.com/imgres?imgurl=http://www.gttkc.co...
I would have recommended to just get a AMD 7750 which performs at same level as the GTS 450 but does not require a PCIe connector. However, I saw that there are $69.99 GTS 450 where the AMD 7750 is usually $109.99
Ask the community
