So i have seen a few threads about diy laptops, none with a built one, and most of them said not possible no standard set of parts. I was thinking of upgrading my netbook with a ssd and a ram upgrade at 1 am when I came up with the idea of a laptop from scratch build using desktop parts which turned into a tablet after looking for key boards and trying to design a hinge and screen that worked.
current system idea-
mini itx motherboard.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121622
Intel pentium dual core cpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116521
8gb ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148276
750gb harddrive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136835
touch screen
Cooling:
-CPU
-Case
4 40 mm fans pushing air in across motherboard 4 40mm fans pulling air out across from the inputs
Case
2"(batteries in bottom 1/2")x9"x11" aluminium for heat and durability.
8gb ram
750gb harddrive
touch screen
Cooling:
-CPU
-Case
Case
