Help choosing a 600-700W PSU
Important specs:
Asus Crosshair V Formula-z
Corsair Vengeance x2 4GB DDR3 1600 Mhz
Antec H20 920
FX 8350
Radeon HD 6950
8 Case fans
Samsung 830 128 GB SSD
I am expecting to upgrade to a crossfire setup in near future, so it should be a psu capable of handling that as well.
I'm trying to find out which PSU i should upgrade to, as the one i'm using right now is not useable for overclocking at all (CM GX Lite 600W)
Money really isn't a big issue, as long as it's in the range of;
100-200$
62,44-124,87£
And as i'm living in Denmark, it is greatly appreciated if you could hook me up with a link/suggestion, to a site that delivers to Denmark.
Help is greatly appreciated :)
9 answers Last reply
More about help choosing 700w
  1. nicko11 said:
    Important specs:
    Antec H20 920
    FX 8350
    Radeon HD 6950
    8 Case fans
    100-200$
    62,44-124,87£
    Hi - here is a link that is probably OK for you:
    http://www.kelkoo.dk/c-110101-edb.html
    or
    www.edbpriser.dk
  2. nicko11 said:
    Important specs:
    Antec H20 920
    FX 8350
    Radeon HD 6950
    8 Case fans
    100-200$
    62,44-124,87£
    Hi again - what does 799 kr equal in dollars?
    799kr is 140 dollars. or 139.09 to be precise.
    And thank you for that link.
    I found the Corsair tx 750 v2 for 799kr - it will handle CF/SLI
    comfortably.
    http://www.edbpriser.dk/stroemforsyning/corsair-enthusiast-series-tx750-v2-id-4700454.aspx
    comfortably.
    Thank you for the help.
    I should have included this in the first post, but i prefer modular, gold / platinum psu's, as it's a pc who is on quite a lot.
    Edit:
    And as a note, i preferably just want a tip to the absolute best in that price range, which is gold / platinum and modular / semi modular.
    Edit:
    In that price range - you are prob looking at Corsair prof
    http://www.edbpriser.dk/stroemforsyning/corsair-professional-series-gold-ax650-id-5343757.aspx
    http://www.edbpriser.dk/stroemforsyning/corsair-professional-series-hx650w-id-649608.aspx
    http://www.edbpriser.dk/stroemforsyning/corsair-professional-series-hx1050-id-5091080.aspx
    http://www.edbpriser.dk/stroemforsyning/corsair-hx750-id-6906629.aspx
    http://www.edbpriser.dk/stroemforsyning/corsair-professional-series-hx750w-id-535200.aspx
    http://www.edbpriser.dk/stroemforsyning/super-flower-golden-green-sf-800p14xe-id-5091486.aspx fairly sure but not 100% sure this is modular
    http://www.edbpriser.dk/stroemforsyning/super-flower-golden-green-pro-sf-750p14xe-id-5091492.aspx
    There's plenty to choose from there
  7. I am liking the AX650 as i can actually see there is sleeved cables that you can buy for it :)!
    Can anyone recommend it? The reviews look nice!
    Professional Series
    CMPSU-650AX ATX12V &
    EPS12V 650 1 x 54 Amps Gold SeaSonic Xbit Laboratories, TechPowerUp
    http://www.techpowerup.com/reviews/Corsair/AX650/
    http://www.xbitlabs.com/articles/cases/display/corsair-ax-psu.html
    AX is their top of the line units - Seasonic(top quality oem) built
    if you need more power than the 650 - the Superflower 800w is an ex unit and is modular
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=229
  9. toyftw said:
    Professional Series
    Looks like it's my pick.
    Thanks a lot for your help mate!
Power Supplies Components
