-What type of screwdriver do I need?
-If my entire house is carpeted, where should I work?
-I am going to be buying an anti static wrist strap. I've heard that touching the outer case of a plugged in PSU will ground you. Could I attach the wrist strap to the PSU? If not, where should I? Where do I attach the wrist strap after I need to install the PSU?
-How do I tell that I am actually grounded?
-I want to get a "Giottos Rocket Air Blower" to clean out dust and whatnot for future use. Which size should I get: small, medium or large?
