The motherboard im using is the ASRock Z77 Extreme4 LGA 1155 every thing looks like its working fine but my keyboard's NumLock, CapsLock, and ScrollLock are all flashing green I think it might be because on my I/O panel there is only one slot for keyboard and mouse it is half green and half purple. I have a usb mouse and it works fine i had to use the onscreen keyboard to register windows tho.
My second problem is that my computer recognized my SSD just fine when i installed windows and after the install I hooked up my HDD to the slot above the SSD and my HDD is not appearing under hard disk drives.
My third problems is that I do not have an optical drive so i cannot install any of the disks that came with my SSD,GPU,and MOBO. Is there a way I can put them on usbs and install them like that?
